Cam help....
Old Jun 22, 2011 | 01:40 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by darnie
well my roomies a diesel mechanic, and also has a 11 second 6 speed 3500, hes good at it just has never done chevys, we got the how too's im just wondering what needed and what you all would do... i bought the cam off a guy i got all the parts needed tho just need to know what else i need. thanks for the help guys..
If he's a diesel tech, he probably hasn't done many cam/valvespring swaps. Here's a link that both of you should read up on before you start. Lots of good tips in here. http://www.ls1howto.com/index.php?article=23 The article was written for an F-body, but almost all of it is the same for these trucks.
Old Jun 22, 2011 | 01:45 PM
TX Tahoe Z71's Avatar
Just did mine this weekend, replaced the timing cover gasket ($26), water pump gaskets (2 of them, $4 each), and crank seal ($14, iirc). We did the air compressor hose in the spark plug hole to hold the valves up and the 3/8" wooden dowel to hold the lifters up. Since you have to pull the plugs, might as well replace those too, NGK TR55's.
Old Jun 22, 2011 | 01:48 PM
^^^ All good advice here.
Off topic--how do you like that GT2-3?
Old Jun 22, 2011 | 02:08 PM
darnie's Avatar
na he does pretty good he works at the mine and is on a rebuild crew. but neways ya i just put new plugs in about 2 months ago same as you all mentioned so should be good there, i just gotta get all the gaskets i guess, then pray my lifters are still good haha. on the timing chain i figure ill change it if its warn, is one set better than another tho?
Old Jun 22, 2011 | 02:11 PM
To be honest, it's pretty nuts. The truck pulls all the way to redline (6200 right now), and pulls harder 70 to 90 than it seemed to 30 to 50. I did a before dyno of 402/455 on a Dynojet with the outside temp at 108 (typical Houston summer, haha) but haven't got it on the rollers yet for an after. I am going to start a thread up about it, but haven't had time to scan the graph in yet, soon though.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
