Cam help
Old May 2, 2011 | 12:18 PM
Pollo432's Avatar
One of those too good to be true moments huh?? I'm looking for a mild cam not too extreme. Just something with a good hp gain, can use nitrous, stock tc and a nice lope of course. Don't mind if I have to change springs but not looking to invest too much in the 5.3 since I just purchased a used lq4 and am planning a 408 build and go all out.
Old May 2, 2011 | 12:19 PM
Mangled03gmc's Avatar
Baltimore Whore
Regrinds are POS's Do not cheap out on a regrind.. And nitrous likes anything...
Old May 2, 2011 | 12:46 PM
dmelvin's Avatar
Originally Posted by Pollo432
He said it's a regrind. Any issues with that type of cam??
Run away fast and don't look back.
There's a couple of cams on here for sale, I know of two low lift 212/216's Check the classifieds.
Old May 2, 2011 | 01:36 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by dmelvin
Different people will give you different answers. The LS6 "yellow" springs are good to .570, the older LS6 springs from 2001 are good to .529, I think the new LS6 springs are blue and they're also good to .570 IIRC.
In 2001 the LS6 had a lower lift cam 207/217 .525/.525
In 2002 they went with a higher lift cam 204/218 .551/.547
If you went with the low lift version of the cam, you shouldn't have a problem with any of them.
Matt@Texas Speed confirmed that the new LS6 spings are in fact blue, and should have the same specs as the previous yellows. Waiting to hear back from him in a thread in the Internal Engine Mod section
Old May 2, 2011 | 03:54 PM
Pollo432's Avatar
Thanks for the info.
Old May 2, 2011 | 11:59 PM
Pollo432's Avatar
Used Comp 239 247 .623 .623 112 LSA cam. How does this cam look??
Old May 3, 2011 | 12:15 AM
Baltimore Whore
Way to big for a 5.3. But would be nice in a 408. Not sure if stock heads will flow what that thing is capable of. You will need a 3600 up converter for that to get the most from it..
Old May 22, 2011 | 12:39 PM
04Burban's Avatar
I'm looking to throw the 212/218 LL in an LQ9...not really looking for peak, just a little better. What kind of gains should I be expecting?
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
