Cam Help
Old Apr 10, 2008 | 11:41 PM
aaronk227's Avatar
Default Cam Help
I am putting a cam in my 4.8 tomorrow, do I need to use cam lube? I know it was strongly recommended on the older motors, but I don't know much about these gen IIIs. Please help...
Old Apr 11, 2008 | 12:33 AM
00Silv4.8's Avatar
all I've heard is to put some fresh oil on it after a real good cleaning with some brake kleen or some TB cleaner
Old Apr 11, 2008 | 01:43 AM
WFOsierra's Avatar
yeah clean it really good with some eather or throttle body cleaner, its a good idea to put some engine asembly lube on there, its cheap and will help the cam break in for the first few miles then change ya oil and you should be good to go....
Old Apr 11, 2008 | 01:14 PM
budhayes3's Avatar
PT's Slowest Truck
I used Federal Mogul engine assembly lube since I had it, but it's not necessary from what I've read. Seems a good coat of oil will take care of it...I'm assuming since it's a roller cam, the lobes aren't an issue, and since the cam bearings are re-used, that's not an issue. No break in or "running in" the cam either...possibly some break in on the valve springs though, may need to let them go through a few heat cycles if they're Comp's.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
