cam help
looking to buy a cam. need some help.want the most power. it s going in a 5.3 with a 3000 stall and 150 shot of nitrous.
Duration @ 050" Lift: Intake 222, Exhaust 224
Advertised Duration: Intake 275, Exhaust 277
Valve Lift with 1.7 Rockers Intake .566, Exhaust .568
Lobe Separation 112
Duration @ 050" Lift: Intake 228, Exhaust 230
Advertised Duration: Intake 281, Exhaust 283
Valve Lift with 1.7 Rockers Intake .571, Exhaust .573
Lobe Separation 112
any other suggestions are welcome.
Lobe Separation 112
Lobe Separation 112
I'm not great with cams but I think the first one would be better for your 5.3L... The 2nd one will have you spinning it too high to make real power. I wouldn't go any bigger than my 226 if I had to choose a new one.
I would recommend going with a 114 lobe separation. It would be benifitial for you to call up Thunder Racing, or any other experienced cam grind tech. and ask them for some advice on a custom grind for your nitrous motor.
ok dont you have a procharger on that thing?
1999 chevy silverado RCSB. Procharger P1SC,12lb pulley, Ls1 edit, cutout,eaton posi,3.73.
i think you will need to stay with a high lsa so you dont have loss of boost. isnt this your mods? i would call thunder or get bigtex to help out on that one. i think another good cam for boost is the lingerfelter gt2 cam.
lawhitediamante
Aug 12, 2015 12:14 PM
