cam and heads?
Old Dec 19, 2005 | 12:05 PM
Default cam and heads?
ive got a lq4 long block to work off of...
im thinking....
p&p/milled ~.020 ls6 heads
~.040 head gasket
will i have any ptv issues?
undecided on a cam.....recommendations?
Old Dec 19, 2005 | 12:38 PM
tdrumm's Avatar
im thinking....
~.040 head gasket
Where did you decide the amount to mill the heads and gasket thickness? Is there a specific compression ratio or chamber volume that you are aiming for? Or is it to get back lost compression due to the porting process?
Piston to Valve clearance has many factors: Piston dish or reliefs, milled heads, and thinner gaskets all play a role in determining p to v, but you also must have a cam in mind. Cam duration and lift play the most important roles in determining piston to valve clearance. I've read that .080 intake and .100 are safe minimum p to v clearances. The only way to be 100% sure is to clay the engine when you are doing the heads.
As for a cam recommendation, I would call a cam grinder and speak to them. Tell them as much about your truck, driving style, and engine combo and see what they say.
Old Dec 19, 2005 | 09:37 PM
reason i wanted to mill the heads was i was hoping for around a 10.5-11:1 CR
im trying to make about 450hp at the flywheel while staying N/A
can this be done with the stock lq4 bottom end?
Old Dec 20, 2005 | 09:19 AM
white1's Avatar
Not to thread hijack, but Ive been tossing around the idea of swapping my 317's for a set of hand P&P LS1 heads. Would the increased compression make up for the lost flow? I know the 5.3 heads boost the compression way up, but the heads dont flow too good at higher RPMs due to the small valves. Just wondering how much flow I would loose with the LS1 heads, I plan to P&P and mill .020, or .030. I have a LQ4, so I have some room to go with the compression. Id like to be around 10.5-10.75 or so.
Old Dec 20, 2005 | 09:21 AM
02sierraz71_5.3's Avatar
its all about the dynamic compression, you should be paying more attention to that than static compression. I wouldnt worry to much about p/v if you go with a cam in the .56x lift range and under 230 duration. you can always clay the heads
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
