Cam experts how would this cam behave?
Old Dec 3, 2012 | 07:32 PM
phasemaster1's Avatar
Default Cam experts how would this cam behave?
2003 Silverado 4x2 5.7 243/799 heads 4l80e stall 2800 3.73 and 28.5" tire.
Intake Duration: 218 Degrees at .050" Tappet Lift.
Intake Lift: .595" with 1.7 rockers.
Exhaust Duration 226 Degrees at .050" Tappet Lift
Exhaust Lift .598" with 1.7 rockers.
113 Degree LSA
Old Dec 3, 2012 | 07:40 PM
03sierraslt's Avatar
I would say a noticeable lope at idle and it would like around a 3200-3400 stall in a 5.7, I am not a expert though so take that with a grain of salt.
Should still have good lowend with that intake duration and LSA. JMO
Old Dec 3, 2012 | 08:47 PM
Pat Im going to keep the baby stall and try it I can always get it restalled. Since I dont think Ill be getting a Badass boat like John(Mangled03gmc) I would use the smaller 9.5" converter.
Old Dec 3, 2012 | 08:49 PM
What stall do you have? Seeing as though you have a RCSB I wouldn't hesitate to run a tighter stall.
charcoal03silvy's Avatar
looks a lot more like a lsR grind for rectangular port heads
Old Dec 3, 2012 | 09:14 PM
Nope eps cam for cathedral port.
Old Dec 4, 2012 | 03:42 AM
Typical rectangular port would have a much larger exhaust bias.
Old Dec 4, 2012 | 08:38 AM
BigKID's Avatar
What is the exhaust setup (headers, y, catback)? An 8* split seems to be setup for a more restrictive exhaust since you have a good set of heads. It should work fine with your existing 2800 converter with the low intake duration and LSA. Any advance ground in?
Old Dec 4, 2012 | 07:53 PM
1-3/4" longtubes 3" y no cats in to Borla XR-1 dumped before axle. Not really sure if any advance is ground in. Didnt see anything on EPS site.
Old Dec 4, 2012 | 08:32 PM
No info listed on the ICL?
