cam - convert
Old Feb 8, 2006 | 08:37 AM
SiniSter5.3's Avatar
Default cam - convert
I have noticed most of the members with cams seem to be in the 210-220
range , and are using 3000 rpm or higher stall . Is there a reason why ?
It just seems like to much stall for a cam with that small of a duration .
Old Feb 8, 2006 | 10:27 AM
TXsilverado's Avatar
my guess is that the smaller cubed 5.3's wont eat a cam like the 5.7/6.0's will.
Old Feb 8, 2006 | 11:15 AM
98TAauto's Avatar
WEIGHT
fbodies weigh 3500 pounds.. we weigh from 4500-5500
our cams are small and the stalls are also. Fbodies that run 230+ cams need big stalls so it all balances out back to the weight factor
Old Feb 8, 2006 | 11:48 AM
Originally Posted by 98TAauto
WEIGHT
understand on the smaller duration cam to help keep the low to mid torq .
but I wouldn't consider a 3000 rpm stall small
Old Feb 8, 2006 | 11:55 AM
my 2600 feels stock. i want 3000-3200 now...
Old Feb 8, 2006 | 12:29 PM
at what rpm is your truck breaking the tires loose if you power brake it ?
Old Feb 8, 2006 | 01:12 PM
it was at 2600 but now i have too much tranny fluid so it is only going to 22-2300 for now. i dont have the tools to pump out the excess tranny fluid here at college it wont hurt anything will it?
Old Feb 8, 2006 | 01:15 PM
ap2002's Avatar
I think he was talking about the stock stall, they are only a 1500rpm...
Old Feb 8, 2006 | 01:40 PM
Yelo's Avatar
You have to remember that even with a "baby cam" and a good set of springs these engines will spin to 6500rpm....a 3000rpm stall isn't all that unreasonable when you can spin that high
Old Feb 8, 2006 | 02:02 PM
no it isn't but the larger the stall the more heat it create in normal driving
conditions and towing .that is what my concern is . I geuss what I really want to know is will my stock convert suffice with a cam around a 220/224 duration?
