cam choice?
Old May 7, 2009 | 12:48 PM
FireMedic331's Avatar
Default cam choice?
I am trying to decide on a good NA/ nitrous cam for my truck. The truck is a 2002 RCSB 5.3. It has intake,ported tb, lpp long tubes, 3400 converter,255 walbro pump, and magnaflow cat back. Im running a 125 dry shot right now, and the truck runs great, best of 7.97 at 90 in the 1/8th with a 2.0 60ft with drag radials. Im hoping with cam and re tune to get closer to the 7.5's. Any suggestions would be great. Also the truck is my DD, and I never pull anything with this truck(ie:trailers,boats ect)
Old May 7, 2009 | 12:57 PM
Bad_Apple's Avatar
Off the shelf probably around TR228, or get a custom grind from Ed Curtis at FTI
Old May 7, 2009 | 09:18 PM
lukesdad04's Avatar
220 or 224 with 580ish lift on a 112 lsa.
Old May 8, 2009 | 02:43 PM
chevyboy_5.3's Avatar
What is the main difference in power output between the 220 and 224? Which one gives you more top end power and which one gives you more low end torque? Those are my two choices in what i want to put in my Silverado
Old May 8, 2009 | 07:46 PM
budhayes3's Avatar
PT's Slowest Truck
The 224 will have more top end and the 220 will have more bottom
Old May 9, 2009 | 09:30 AM
fredkj3's Avatar
more duration.. more top end.... i went with a 224/228 and am very satisfied.... it put down 364 hp. 374 tq.... at the wheels at 4,000
kush killer
Feb 17, 2016 09:20 PM
JordanH
Aug 8, 2015 07:59 PM
sTNT971
Aug 7, 2015 09:05 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
steves86ta
Jul 28, 2015 10:21 AM
