cam change question
Old Dec 18, 2007 | 11:50 AM
OnyxSilveradoSS's Avatar
when I did mine I used rods
and I turned the engine over to have the cyl hold the valves up when I was changing the springs on that cyl, then rotate and do it again...if the valve slides down a bit pull it back with the pen mag.
get ready the springs are fun
Old Dec 18, 2007 | 05:38 PM
Wheatley's Avatar
Truck Sponsor
If you spin the cam to throw the lifters up,pull the old cam out and immediatly put the new cam in,do not go have a lunch break.LOL
Old Dec 18, 2007 | 06:54 PM
NyteSnyper's Avatar
+1, or have some subwoofers hittin hard real close by, or fall and rock the truck... all could equal a bad day.
Old Dec 18, 2007 | 08:12 PM
87silverbullet's Avatar
Originally Posted by ZZebes
if the lifter falls you also have to pull the pan to get to said lifter
Not necessarily so. My buddies 99 ws6 dropped a lifter in the oil pan and I was able to take a flex magnet and go down the driver side of the engine oil pan and fish out the lifter. so try that before you start to pull the pan off.
Old Dec 18, 2007 | 08:23 PM
Jeaux's Avatar
Default busted lifter
this is what repeated 7000 rpm shifts on nitrous does to a lifter in a 94000 mile motor
Old Dec 18, 2007 | 10:00 PM
1989k1500's Avatar
Ive always had two people so we could have the new cam oiled up and ready when we pulled the old one out.
Old Dec 18, 2007 | 10:56 PM
MGMC's Avatar
12 Second Club
i used these instructions http://www.ls1howto.com/index.php?article=23
Old Feb 2, 2008 | 01:02 PM
timmer1's Avatar
Originally Posted by MGMC
I was looking at the instructions and it seems it would be pretty easy to make some of those lifter tools. Anybody know how long they have to be? Why does it say there is a left and a right? They look the same to me.
Old Feb 2, 2008 | 02:01 PM
dirt track racer 81's Avatar
just use a dowel rod..cheap easy and never fails
Old Feb 2, 2008 | 04:36 PM
timmer1's Avatar
only thing I worried about was if the wooden dowel rod shed off any wood while sliding it in or out of there. I can usually get aluminum dowel rod fairly easily, but wasn't sure how long it has to be. When you put the dowel rod in, is there a matching hole it goes in on the back side or is there something it rides on all the way back? Thanks.
