Which cam?
Old Sep 8, 2019 | 06:17 PM
Jseal52's Avatar
Default Which cam?
Truck is a 5.3 with little turbo and mostly a street truck with the odd trip for drag nights. Leaning towards btr or the dumpster fire cam.
https://www.briantooleyracing.com/bt...cam-41533.html
https://www.texas-speed.com/p-8361-c...-fire-cam.aspx
https://www.texas-speed.com/p-8574-t...turbo-cam.aspx
https://www.texas-speed.com/p-8575-t...turbo-cam.aspx
Old Sep 8, 2019 | 07:52 PM
arthursc2's Avatar
I have a cam for sale that'll work ******* for you
Old Sep 8, 2019 | 07:58 PM
ZO6Ted's Avatar
Lol. Yes you do and ******* are awesome!
Old Sep 8, 2019 | 08:57 PM
03sierraslt's Avatar
How small of a turbo? What boost and rpm do you want ?
Old Sep 8, 2019 | 11:04 PM
Jseal52's Avatar
I have a single 70mm right now but will go to a 76mm ball bearing. Boost level would probably be 15psi and 6500rpm give or take.
Old Oct 9, 2019 | 08:44 AM
Summitracing's Avatar
LS1Tech Sponsor
We have our line of turbo camshafts that perform well and are competitively priced. Our stage 1 ghost cam would be a great sleeper cam with a mild noticeable lope. 2,500 rpm stall converter recommended but not required.
Or you could go with the stage 2 turbo cam. The stage 2 will have a steady lope. It spools quickly and pulls hard in the mid-range and has a great top-end. 2,800 rpm stall converter recommended.
jmgak47
Oct 8, 2017 08:29 PM
chvy=power
Apr 20, 2015 11:50 AM
tylerj
Aug 3, 2014 02:58 PM
supadaddy
Sep 8, 2009 03:09 PM
RED2K
Apr 11, 2003 02:20 PM
