cam 112+4
Old Feb 7, 2007 | 09:47 PM
regency's Avatar
Default cam 112+4
say the cam has a 112+4, can you put it in so that it isnt advanced any, so that it is really hitting on the 112 lsa. Or am i making any sence at all?
Old Feb 7, 2007 | 09:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The +4 is 4* advance ground into the cam. The LSA (lobe seperation) does not change.
As I understand it.
Old Feb 7, 2007 | 10:07 PM
RWC's Avatar
RWC
Yes, if you retard it 4 degrees it would be the same as a 112+0 or 112 LSA and 112 ICL. If you install it dot to dot it would be a 112 LSA and 108 ICL. And trever1t is right, LSA is ground into the cam and cannot be changed.
Old Feb 7, 2007 | 11:45 PM
regency's Avatar
i know it cant be changed on the cam itself!! lol!! but retard it that 1, 2, 3, or 4 degrees. seriously what would be the difference between a 112+4 and a 116+0 both being 224/224 with .58x/.58x lift
Old Feb 7, 2007 | 11:49 PM
negativeswitches's Avatar
difference is the speration angle between the intake and exhaust lobes
112+2 112+4 112+30 is still 112* between the lobes
all the +# does is pre dial in the cam if you didnt per say have an adjustable timing set
Old Feb 8, 2007 | 01:03 AM
FarmerBeau's Avatar
Sexy Party Mod
You can have a custom ground cam to those specs if you want. I had mine ground on a 110*+0. Otherwise you need an adjustable timing set for those type of adjustments.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
