cam with 1:8 roller rocker?
Old Oct 23, 2005 | 05:07 PM
Tweaked 5300's Avatar
Default cam with 1:8 roller rocker?
hi eveyone
for my 02 silverado with 5.3L auto, what cam should i use with my crane 1:8 roller rockers and have a awesome lope?
thanks
Old Oct 23, 2005 | 05:22 PM
mattrem's Avatar
Are they the "Quick Lift" Rockers? You cam choices will be limted cause of those rockers. Some cams are not made to be used with 1.8s.
I use 1.8s on a Comp 216/220 in my truck and it has a slight lope, mine is a 6l thought.
Cam choice will depend on alot of other factors, Do you have any other mods?
Crane and DeVinci have cams made for use with those rockers I believe.
Old Oct 23, 2005 | 05:41 PM
99Silver6.0's Avatar
Originally Posted by Tweaked 5300
hi eveyone
thanks
Depends on the cam. Most cam peeps recommend NOT using 1.8's with anything. Unless you get a minuscule cam.
Idea......
Ditch the rockers, sell them. Then buy a big cam. Easy.
Old Oct 23, 2005 | 06:18 PM
98TAauto's Avatar
i never understood why some get rockers.. just get a cam with high lift which would save you 400bucks for rockers since.
is your truck 4x4? Do you have a stall?
a 216/220 cam is gonan beed a good 3k stall to get low end back. A 210/218ish type cam with keep low end without a stall. But they make those cams with .550lift and you could get a custum deal with even higher lift and then sell the rockers. Whatever you get keep in mind that springs might need to be upgraded also. Its alotta different combos you can go with so its up to you. Rockers arent gonna make any cam lope, you just get more lift. Lift makes more power normally.. Duration/lsa makes the lope:-P
Old Oct 23, 2005 | 07:24 PM
litreddevil's Avatar
Banned
I Have A 216/220 If You Go With A 117 +4 Center You Will Get Your Bottom End Also
I Have 1.85 Rockers On The 216/220 Cam In My 6.0 And Love It
I Would Tell Everyone To Get After Market Rockers Cause The Stock One R Not As Strong And The Stock Ones Loss Their Bearings
Old Oct 23, 2005 | 07:34 PM
bluecajun5.3's Avatar
11 Second Truck Club
mines is pullin strong after 36k warranty, lol...
DrX
Aug 19, 2015 04:45 PM
Hmguyton
Aug 9, 2015 05:38 PM
BigEd_72455
Aug 8, 2015 07:37 PM
4B11T
Jul 13, 2015 03:48 PM
supersportsteve
Jul 4, 2015 12:02 PM
