calling all machinists....
I need the cylinder head specs for the 5.3's, as I am about ready to do some porting and polishing, and would like to know the suggested specs for these heads, as in should I go with a normal 30-45-60 valve job or is there something else these engines like? Also, any other specs would be appreciated like valve seat angle, backcut angle, min. valve margin, etc... Thanks a bunch.
these are stock values:
valve face angle: 45 deg
valve seat angle: 46 deg
valve seat runout: .002" max
valve spring pressure opened/closed: 76 lb@ 1.8"/220lb @ 1.32 in
those are about the only values I have that might help. Ive got a full spec sheet on lm7 vin t / l59 vin z engines
thompson
Dec 27, 2017 06:48 AM
I owe you one.
