C5 Cam
Old Dec 5, 2004 | 06:49 PM
nightmarechevy's Avatar
Default C5 Cam
Anyone know if the stock C5 cam will produce any gains in our trucks? I know the Z06 cam will, just wondering about the C5. Also, what are the specs on it? Thanks in advance for your help.
Old Dec 5, 2004 | 07:00 PM
Sport Side's Avatar
Check this out here.
Probably similar to one of these.
1998 - 2000 Fbody
202/210 .496 116lsa @ .05
2001 - 2002 Fbody
197/207 .467 .479 116lsa @ .05
Old Dec 5, 2004 | 07:11 PM
Thanks. Will the gains in these be worth the trouble to change?
Old Dec 5, 2004 | 07:12 PM
Sport Side's Avatar
You'd probably see a few ponies here and there. Just a guess though. Private Message, Big Kid. He used one. See how he felt about the gains.
Old Dec 5, 2004 | 07:15 PM
Ok, I will. Thanks for your help.
Old Dec 5, 2004 | 09:39 PM
goshawk23's Avatar
Truck addict
that cam is now in my truck. he hit 300 hp n/a with that cam in his truck. albeit he had other mods as well.
what i noticed in my truck with a 2000 vette cam is i lost some bottom end. however, at 4000 rpm it pulls a hell of a lot harder. i am not using the full potential of this cam yet either. my programmer has the rev limit set to 6000 and it wants to pull a good bit past that. also, i dont' have headers. all in all, for a good cheap cam, this is it. i would do it again. it cost 40 bucks to buy the stuff needed to install it. such as the water pump gaskets, crank bolt and front seal, and gasket.
Old Dec 5, 2004 | 10:09 PM
Yeah, I have a guy that can get me one at no charge. I should still be ok with bottom end because of the 4.10s but could definately use a little more in the higher rpm range.
Old Dec 6, 2004 | 06:07 AM
sfj
what goshawk23 said you lose some bottom end just like the zo6 cam a few pound feet of torque are lost but with that i am guessing about 25+ rwhp would be gained i know on the zo6 you gain about 35+ most of the time from personal knowledge and everything i have read hope this helps
Old Dec 6, 2004 | 07:43 AM
goshawk23's Avatar
Truck addict
i installed 4.10 gears as well and got my bottom back. basically after the cam and no good tuning i went from 2.3 60's to 2.4 60's. then with the gears i went back to 2.3 and 2.2's. we'll see what it does with a better tune, converter and hopefully some headers soon.
Old Dec 6, 2004 | 08:34 AM
I have a Nelson, so free retunes if I get one. My 60s are in the 2.4s but I usually have crappy traction off the line. Maybe the C5 cam will actually help me get better traction on my launches?
