C1 Hammer Cam
Old Jul 14, 2002 | 06:08 PM
99Silver6.0's Avatar
Default C1 Hammer Cam
OK, Im getting ready for my cam install. I just have a few things I need some help with. After I get the cam in will I need to a bunch of tuning with LS1Edit or will I be ok witt he stock PCM program? Friend told me I will need to drill out the hole in my TB butterfly to accomodate for the idle. Would it also be a good idea to change the pushrods and valve springs while Im in there? Anyone else who has done a cam in a 5.3, what all did you do after the install to get your truck running good? Any help would be greatly appreciated!
Old Jul 14, 2002 | 08:41 PM
BigTex's Avatar
Default Re: C1 Hammer Cam
It should lope pretty good. I have a little LS6 cam, and it idles like stock, so I needed nothing else with it. I am interested in hearing your results. Please post them up when you get finished with the install.
Old Jul 14, 2002 | 10:28 PM
Ill post my dyno sheet after I get it in. I should be able to get it done before long. I wanna head to the dyno to see how much HP I can put down before I do the cam. Im gettin anxiouos!!
Old Jul 14, 2002 | 10:33 PM
Ryan23silverado's Avatar
What are the specs on the C1 Hammer Cam?
Old Jul 14, 2002 | 10:59 PM
QuickSilverTA's Avatar
222/222 .566/.566 112lsa
Old Jul 16, 2002 | 12:32 AM
RED2K's Avatar
I AM TRYING TO DECIDE ON A CAM FOR MY TRUCK. EITHER GM'S HOT CAM 525 & 525LIFT 219 INT. 228 EX@ 112 OR THE GEN3 CAM. COMP SAID TO TRY A 214@50 WITH 522 AND 529. I AM GOINGT O USE THE LS6 SPRINGS. I BOUGHT SOME EDLEBROCK HEADERS AND A A.T. RELOCATER FOR IT. I STILL PULL A HEAVY LOAD FROM TIME TO TIME {5000 LBS}, SO I KNOW I DONT NEED A HUGE CAM BUT I WANT TO HEAR IT AS WELL. WHAT DO I DO? HURRY 98PEPPERZ
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
