burning oil?
Old Feb 18, 2014 | 08:11 PM
jeffz0rz's Avatar
Gray in color, only at WOT or first thing in the morning. A little over 2 quarts per oil change. Yikes.
Old Feb 18, 2014 | 08:15 PM
03sierraslt's Avatar
Originally Posted by trxmxzx
From the last engine builder I talked to he was upset with the " dinosaur oil " I used in my boosted motor. He said use ams or royal purple. I told him I was also using Lucas oil stabilizer he almost threw up. I told him it's worked so far he just stopped talking to me
Personally I would avoid additives like that as in many cases they have been proven to cause oil aeration.
Old Feb 18, 2014 | 08:17 PM
GMCtrk's Avatar
Valve seals are probably shot
Old Feb 18, 2014 | 08:29 PM
MasonB's Avatar
Registered User
Yea one of my valves sticks sometimes and will smoke when I start it but it's not every time
Old Feb 18, 2014 | 08:30 PM
trxmxzx's Avatar
13 Second Truck Club
Damn thanks for the heads up on that
Old Feb 18, 2014 | 08:34 PM
MasonB's Avatar
Registered User
Gray can also mean it's burning trans fluid from what I've read
Old Feb 18, 2014 | 09:43 PM
batboy's Avatar
11 Second Club
Check for leaks and do a compression test.
Old Feb 18, 2014 | 10:12 PM
jeffz0rz's Avatar
No leaks, and will do a compression test asap.
Old Mar 5, 2014 | 11:00 AM
Okie5.3's Avatar
Is this a AFM (displacement on demand) truck? The AFM trucks have had issues with oil consumption, more so than non-AFM trucks. If it is AFM the consumption could be from blow-by past the rings. The pistons tend to get extreme amounts of carbon build up causing the rings to stick resulting lots of blow by. This could be enhanced by the oil squirter as well. The AFM lifters have also contributed to the oil consumption issue. The PCV orfice could have an issue causing oil to be pulled into the intake. There is an updated valve cover to supposedly solve this. Pull the throttle body and check for oil in the intake. If there is more than a light film of oil in the intake, I would start with the easy fixes first, such as pulling the lsft valve cover and checking the orfice and surrounding area for any signs where oil could be pulled through into the intake.
Old Mar 22, 2014 | 08:35 AM
TLoke13's Avatar
Is smoke on acceleration or decel? Or always? And cylinder mis firing?
