Built a stronger flywheel
Old Jun 30, 2003 | 04:21 PM
408 Stepside 01's Avatar
Default Built a stronger flywheel
Since no one has a aftermarket flywheel. For those of you who have run into the same problem as me. I ended up buying two stock flywheels and cutting one of the flywheels outer teeth off. Then i welded them together and had them balanced. I will let you know how it holds up.
Old Jun 30, 2003 | 05:38 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Built a stronger flywheel
So now you have a flywheel with two inner sections welded together? Cool deal, let us know how it works out.
I think TCI is coming out with a SFI certified flexplate soon but, as of now it's not out.
Old Jun 30, 2003 | 06:23 PM
Hughes is also making a SFI flywheel. He said it should be out in about a month, which usually means three. I couldnt wait though.
Old Jul 1, 2003 | 03:35 AM
Flyer's Avatar
Did you cehck with Scat? I think someone was telling me that they may have one. I don't know if they would have one for the LS1 flavor engine though.
Old Jul 1, 2003 | 06:48 AM
TCI makes one too.I've seen it disscussed in the automatic transmission section.
Old Jul 1, 2003 | 02:50 PM
gonzo 6.2's Avatar
Will the torque converter slide back far enough and not jam into the pump gears?
Old Jul 1, 2003 | 03:37 PM
I checked with TCI. They said that they dont have one for our trucks yet, but they also plan on making one. And yes i am worried about the clearance between the two. With my last converter i had a lot of room to adjust. But now that i got the yank i dont know. It is only going to offset it about an 1/8 of an inch. I am pritty sure it will have enough clearance, but i guess will see.
nabozny21
Oct 17, 2015 07:47 PM
turbo6c3
Oct 5, 2015 06:11 PM
Mark_k
Oct 1, 2015 11:17 PM
jtphelps289
Sep 30, 2015 09:26 PM
DrX
Sep 29, 2015 04:31 AM
