Building an LQ9.....
Old Nov 25, 2005 | 01:17 AM
thunder550's Avatar
High on diesel fumes
Default Building an LQ9.....
So I decided the cheapest way for me to get my LQ9 is to build one, and I started my acquisition with the rotating assembly that I just bought from grippy. My question is this: how much of the 5.3 stuff can I use in the 6.0? I know I need a 6.0 block and 317 heads, but will everything else swap over? i.e. timing covers, oil pump, lifters, oil pan, flywheel, etc etc etc?
Old Nov 25, 2005 | 02:05 AM
Rhino79's Avatar
9 Second Club
Yup, everything will interchange.
Old Nov 25, 2005 | 12:34 PM
zippy's Avatar
everything should interchange, but finding the LQ9 specific crank and rods can be a bit tough.
Old Nov 25, 2005 | 01:38 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I took all the sensors, flywheel, replaced the oil pump but it was the same, pretty much everything off the 5.3 and put it on my LQ4.
Old Nov 25, 2005 | 06:15 PM
thunder550's Avatar
Sweet...I already got the hard part done then, the LQ9 pistons, rods, and crank I just bought from grippy, so all I got left is a block and heads, then I can start building! Thanks all.
Old Nov 25, 2005 | 06:51 PM
Kano's Avatar
I gotta say
you got a nice deal
200 for the rotating ***
just think...
695 for a 6.0 Iron block from sdpc and thats
basically a brand new LQ9 short block for around 1000 bucks
any thoughts on heads and cam choices?
I like the idea of a radix on a H/C LQ9 after the truck already turned a 13
with the 5.3
Old Nov 25, 2005 | 06:59 PM
treyZ28's Avatar
pshht, I got you all beat. $2000 for a new 2004 crate LQ9 complete from injectors to oil pan, waterpump to flexplate with GM plugs still on the ends of the hoses. Ohh yeah, thats delivered to my door
I got hoed on the trans though. $750 for one that was taken out of a denali that was wrecked on delivery (7 mles). Came with the converter. No core
sorry, i'm a bragging jerk
Old Nov 25, 2005 | 07:33 PM
Kano's Avatar
OK
good deal though
Old Nov 25, 2005 | 07:50 PM
budhayes3's Avatar
PT's Slowest Truck
For heads you might as well just get a nice built set from WCCH...might be a core charge I guess, but in the end you'll end up with some nice worked heads.
Old Nov 25, 2005 | 08:23 PM
Kano's Avatar
Id get the ones just like grippys with the 73cc chambers
