Broken Intake bolt
Old Feb 22, 2008 | 09:02 PM
tarinitup's Avatar
9 Second Truck Club
Default Broken Intake bolt
Who has ever broke an intake bolt and how did you get it out. The one I broke also happened to be the furthest one back
Old Feb 22, 2008 | 09:12 PM
jkwalkercchs's Avatar
intake manifold bolt???
how??
Old Feb 22, 2008 | 10:23 PM
tarinitup's Avatar
9 Second Truck Club
yeah intake manifold bolt. I was trying to figure out why my AFR increased a whole point from one day to the other and figured my intake may be loose. I started tightening and broke the last bolt on the drivers side. I assume I can still use the truck as long as I take it easy and make sure AFR is below 16 at cruise.
Old Feb 22, 2008 | 10:27 PM
yea idk thats crazy u will have to have it removed at a machine shop o do it yourself either way want be fun
Old Feb 22, 2008 | 11:37 PM
53bowtie's Avatar
pull the intake and get a pair of vise-grips on it.....if that dont work drill it out and retap it, thats about the only options....
Old Feb 23, 2008 | 03:31 AM
if u need a bolt pm me a got a couple extra
Old Feb 23, 2008 | 12:17 PM
fastgmc53's Avatar
14 Second Truck Club
You could use an eazy-out. You drill a small hole in the bolt then the eazy-out is reverse threaded, as you turn the boltcounter-clockwise it threads down into it until it bites and comes out. It should work on the intake bolts because they are aluminum so they shouldn't be that tight.
Old Feb 23, 2008 | 01:24 PM
DrX's Avatar
DrX
The bolt will probably be pretty loose in there once the tension is off of it. When it happened to me I was going to drill the bolt to use an extractor. But I noticed that the bolt was moving around a bit. So I was able to gradually spin it out just by catching a screwdriver against the ridge at the break. I would just remove the intake and try this.
Old Feb 23, 2008 | 03:25 PM
tarinitup's Avatar
9 Second Truck Club
Thanks for the replies. I is windy as hell today so I haven't even taken off the intake.
Old Feb 24, 2008 | 07:51 PM
tarinitup's Avatar
9 Second Truck Club
Bolt is off after 4 hours, 4 drill bits, and 2 extractors. I was a PITA because the drill barely fit between the head and firewall. When I saw the bolt finally lift it was like getting flashed by a hot chick. I was very happy. I removed about an inch of broken bolt and even had to beat my drill when it came out because it jammed it to the firewall. Felt do this on my own instead of paying out the *** for a mechanic to do it.
