broken bolt..best header gaskets?
Old Jul 22, 2009 | 02:51 AM
bubbakutz's Avatar
looks like the stock gaskets are they way to go. so the only way to stop it from leaking if it does is the copper rtv? anyone have a part number for the stock manifold gaskets?
Old Jul 22, 2009 | 05:59 AM
seltaeb's Avatar
#15035747 - Right
#15077362 - Left
Old Jul 22, 2009 | 09:52 AM
bubbakutz's Avatar
thank you.
Old Jul 22, 2009 | 09:58 AM
bubbakutz's Avatar
also, anyone know off the top of their head what size diameter and length the locking header bolts i need are?
Old Jul 23, 2009 | 02:25 AM
CoorsLightCoupe's Avatar
the bolts are 8MM x 30mm or so. I just put my LPPs in last week, and like you, I was missing the head off the back driver's header bolt. As for gaskets, i just ran a 3/8" bead of copper RTV all the way around the ports on the headers the day before the install. Once i noticed the missing bolt, i put a little more fresh RTV over that port to help. Re-used the stock bolts (with a little anti-seize on the threads) and bolted them up. No gaskets, just the copper RTV. No leaks, no problems, and i recommend this procedure to anyone. IT hasnt failed me in the last 4 cars i've done it to. Even in my old coupe, i was missing 2 header bolts and another 1 or 2 were loose on the same flange, and i still didnt have any exhaust leaks. Plus i figure if the turbo guys use copper to seal their turbos to the flanges, it should be good for a n/a application.
Old Jul 23, 2009 | 04:36 PM
bubbakutz's Avatar
cool thanks. let me try to find some locking bolts now.
Old Jul 23, 2009 | 08:22 PM
bubbakutz's Avatar
i was thinking about getting these. can someone confirm that they are the right size?
http://www.summitracing.com/parts/PHP-20008/
Old Jul 25, 2009 | 07:59 PM
look about 5mm too short and 50 bucks too expensive. Just re-use the stock bolts or go to your local hardware store and get some strong 8mm x 30 bolts. The store i went to here in my hodunk-podunk town had allen head bolts and the reduced head-size hex bolts, and either way would have cost me about 8 bucks.
Old Jul 25, 2009 | 09:43 PM
Faze2183's Avatar
imo compare the bolt size, to the bolts that come with the LPPs
i replaced mine with some stage 10 bolts from a local nuts n bolts store... the head on them are 13mm
do not use the lpp bolts their cheap as hell, and will break...
Old Jul 25, 2009 | 11:10 PM
the bolts that came with my lpps were 35mm long. they were like 5mm longer than the stockers.
