Broke it...halp!!!
Old Aug 14, 2015 | 12:26 PM
madmann26's Avatar
Default Broke it...halp!!!
So, was driving home and was doing some spirited driving on some curves.
Was going left around a curve and all of a sudden it starts smoking.
It's oil smoke for sure and feels like I lost a couple of cylinders. It smokes when I accelerate or give it more pedal.
170k'ish 5.3 that has had the oil changed about every 4k.
Need some ideas that are budget friendly please.
Old Aug 14, 2015 | 01:20 PM
ss4chad's Avatar
12 Second Club
Lost a ring - Valve Guide - those are my guess's.
Chad
Old Aug 14, 2015 | 01:37 PM
Atomic's Avatar
I have a gauge for that
Do a compression and leak down test. When you take the plugs out will most likely tell you which cylinders to expect problems from.
Old Aug 14, 2015 | 02:27 PM
madmann26's Avatar
I'd rather pull it and throw some cubes at it.
Thoughts/suggestions?
Got about $5k to use.
Old Aug 14, 2015 | 02:41 PM
ss4chad's Avatar
12 Second Club
Stroked 383, I like those motors!
Chad
Old Aug 15, 2015 | 09:27 AM
madmann26's Avatar
What would be the chances of that when I was banking that hard left, oil puddled in the passenger head, got past the seals causing the smoke which fouled some plugs?
Still got the knocking however.
Old Aug 15, 2015 | 01:59 PM
madmann26's Avatar
Welp
Pulled the plugs. The last cylinder on the driver side is the bad one. Spark plug was coated in oil, heavily.
Need some ideas on replacement.
Need to reuse my stock intake and accessories.
Old Aug 15, 2015 | 09:02 PM
ZO6Ted's Avatar
No replacement for displacement. Check Thompson Motorsports one of our sponsors.
Old Aug 17, 2015 | 09:16 AM
GMC93's Avatar
https://www.performancetrucks.net/fo...engine-539166/
I would maybe look elsewhere for another builder...
Old Aug 18, 2015 | 07:12 PM
madmann26's Avatar
I picked up an ATK HP93.
Should be on the road early next week.
