borla exhaust any good?
im in the process of redoing my exhaust, ima do a true dual setup, i have pacesetter LTs and ima run no cats and and then a X-pipe then out to 2 oval mufflers, i dont know what muffler i should go with, i hear from a few people that borla is pretty good but just wanted some opinions on them to see if i should use them on my setup. Thx fellas
borla is one of the best muffler's out there, but for their price I would seriously consider a hooker aerochamber,,,, longtubes, no cats, hooker aerochambers = well I recommend a hooker is you are not running cats...
Good exhaust system idea. Since you want to run a true dual setup, I would choose either the Borla Turbo XL muffler or a custom stainless steel Magnaflow muffler. Both Borla and Magnaflow have "race" mufflers if you are willing to spend extra money. Flowmaster would have been a good idea 10 years ago, lol.
if i had the money i would go with pacesetter LT's no cats w/ hooker aerochambers and no x-pipe unless u r running full exuast and 450 HP, i have a flowmaster cat-back not to exited about it but the install took about 45 min. there is an old post comparing flowmaster and the aerochambers with a video hookers sound alot meaner not sure about the noise inside the cab tho.
nick
nick
What's the difference between the Turbo XL muffler and then the regular borla muffler? Also what's the difference between getting a center/offset muffler as opposed to a center/center muffler?
I recommend the borla Muffler PROXCESS or XR-1 they both sound great. I have a PROXCESS 3" in and dual 2.5" out all the way to the back with no cats.
2004 Chevy LS
RC/SB
LM7 5.3L
4l65E w/SHIFTKIT,VETTE SERVO
2200 TQ Converter OEM unit reflash
G80 w/3.73
ADD ons: LS1 electric Fans,TB bypass, TB spacer, 160* Thermostast, MAC Cold air induction, Borla ProXcess Muffler w/Tailpipes and no cats, NitrousWorks 150 shot, HP Tuners Tune, 295/50r16 BF GOODRICH radials.
Future Mods 6.0L, patriot 5.3L Stage 2 head and cam kit, Vigilante 3000 stall, 4.10 gears Longtubes and OFY pipe, TNT N2O set up.
Team/ NLHP Engine Works
2004 Chevy LS
RC/SB
LM7 5.3L
G80 w/3.73
so does anybody know the difference between the center/center and the center/offset? Also the difference between the regular borla oval muffler and the borla XL muffler?
Center/center is the inlet is in the center of the muffler and so is the outlet. A center/offset is where the inlet is in the center and the outlet is offset to one side. I suggest getting center/center, cause you'll have to turn the mufflers on their sides to work w/ a center/offset.
