Boost-A-Pump for NA Application?
Old Dec 9, 2007 | 12:09 PM
PlatinumHemi's Avatar
Default Boost-A-Pump for NA Application?
Just wondering if any of you GM guys are using Kenne Bell Boost-A-Pump or MSD Fuel Pump Booster on an NA truck.
My stock fuel pressure is 58 psi but when I go WOT it drops down to 55 psi. I'm running a 383 Hemi Stroker motor with 40# injectors.
Rather than installing an inline pump or making some major modifications to the fuel system, I was wondering if there was someone here running a Boost-A-Pump to fix a fuel pressure drop issue.
Thanks,
PH
Old Dec 10, 2007 | 02:19 PM
Help
PH
Old Dec 10, 2007 | 05:13 PM
03sierraslt's Avatar
I wouldnt think it would work being that it uses positive pressure to activate a higher voltage. My take is no boost, no higher voltage. Unless you can set them to activate at like -2vac???
Old Dec 10, 2007 | 09:01 PM
philntx's Avatar
They make an actuator for N/A motors.
Old Dec 10, 2007 | 09:32 PM
kingots2004's Avatar
i installed an intank walbro pump in 45 min thats the path i would take.its so easy
Old Dec 11, 2007 | 06:31 AM
Yeah, there is a Boost-A-Pump for N/A use that uses a Vacuum switch and activates close to 0 vacuum.
There isn't one dodge guy with a Hemi Ram running an in tank walbro pump. Not sure what the reason is.
Anyone here actually use a Boost-A-Pump?
PH
thompson
Dec 27, 2017 06:48 AM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
nabozny21
Oct 17, 2015 07:47 PM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
