Blown engine. Literally. Time for Stroker!
Old May 22, 2014 | 08:13 AM
Default Blown engine. Literally. Time for Stroker!
Hey guys,
So I seem to have blown my engine. I thought it was the lifters and/or cam from the drop in oil pressure and a loud sewing machine noise but they both seem to be fine. I'm speculating it might be either the connecting rods or crankshaft. However, if that's the case, I will be looking to buy a stroker kit. I have came across some really good deals on ebay. Can you guys help me choose the right one? Thanks!
Really appreciated.
Old May 22, 2014 | 08:23 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
That's too bad, but a chance to build it better. I'd skip eBay unless it's a really great seller with LOTS of feedback...I would call up Beau @ TSP and let him help you instead.
Old May 22, 2014 | 08:57 AM
Vortec350ss's Avatar
That was quick...
Sorry to hear that. Can you post a video of what it sounds like?
Just my opinion... but I'm not sure a stroker is the way id go. I'm sure many will disagree with me, but I dont like how far they pull the piston out of the cylinder on the bottom.
Old May 22, 2014 | 09:59 AM
Unfortunately, we pulled the engine out and apart. Didn't get the chance to take a video. So the connecting rods bearings are broken and the crankshaft is also damaged. I think we traced the problem to the Melling oil pump failure. This pump is brand new and I just finished the install around 2 weeks ago. What do you guys recommend for oil pumps?
Old May 22, 2014 | 10:19 AM
I think most just use stock oil pumps. Maybe have it ported... but stock seems to work well for most.
Old May 22, 2014 | 11:11 AM
Atomic's Avatar
I have a gauge for that
Did you make sure to properly align the pump on the crank?
A stroker may not be needed depending on your goals.
Old May 22, 2014 | 11:27 AM
I'm not sure what the shop did but I will definitely make sure of it this time. It was super fine for 2 weeks and all of sudden gave out yesterday. What makes you say a stroker may not be needed?
Old May 22, 2014 | 11:48 AM
Atomic's Avatar
It has its own set of issues, so depending on goals it may not be the way you want to go.
Old May 22, 2014 | 08:21 PM
LsF-150's Avatar
Was the correct pick-up tube o-ring used? Better make sure or your new motor will end up where this one is.
Old May 22, 2014 | 09:06 PM
Chevy_King1500's Avatar
I would get a junk yard 6.0 and throw it in.
you can't beat the reliability of a GM built engine
GXPJAY
Feb 13, 2022 08:15 AM
2500ZL1
Jan 25, 2016 06:30 AM
chevysten
Aug 13, 2015 07:36 PM
black00chev
Aug 12, 2015 01:56 PM
Austino
Jul 30, 2015 03:28 PM
