Black02Z71
Old Oct 16, 2004 | 04:27 PM
slowprocess's Avatar
Default Black02Z71
What's the tps? Do I unplug it, screw in the screw, then turn on the key, wait, then plug it back up? Thanks
Old Oct 16, 2004 | 05:50 PM
Black02Z71's Avatar
TPS is the throttle positon sensor.
Here is thread on how to do this.
https://ls1tech.com/forums/showthrea...op+drilling+tb
Old Oct 17, 2004 | 03:55 AM
Thanks a ton. I didn't get a chance to do it tonight. I don't have Autotap, so can I still do this? I have got to fix this thing. It is driving me crazy going dead at stop signs! It runs so good through the gears, just some times it idles fine and sometimes it won't idle for crap.
Old Oct 17, 2004 | 07:08 AM
one03sierra's Avatar
Formerly one92rs
Talking
yes you can still do it. i dled mine up a tad while it was running and found the sweet spot. then i did the unplug thing and all and it worked. if you go to far it will throw a ses light for idle things i think. but if you reset it with those instructions you should be fine.
Old Oct 17, 2004 | 09:26 AM
gonzo 6.2's Avatar
To get mine to idle perfect i took the throttle stop screw out of the TB and put it in from the top,now the adjustment is on top,mine idles perfect at 675 RPM,I did slightly enlarge the hole in the TB.
Flyer
74
Dec 8, 2004 11:13 PM
