Best place to find 14 bolt rearend?
It sounds like something broke in the 10 bolt,where is the best place to find a 14 bolt rearend from a 3/4ton Suburban?I figure if I can find a 14 bolt add a gear and a Eaton Posi,then bolt it under the Tahoe.
I have seen a lot on ebay, but your local privately owned gear shop should know where to get one, if they are into 4 wheelers and the like. My local gear shop gets 'em in all the time.
Don't forget it's an 8 lug unit. You're gonna have to get 6 lug axles made for it. I dunno if you can get 6 lugs out back and use the 10 bolt brake setup... as I think the 10.5" is a full floating rear axle and the others are semi.
If you're gonna keep the 8 lugs... is it possible to put 8 lug front rotors on your 'Hoe? I'd ask Neil 6.0 or 1BADHD, they should know more about the HD axles. |
You can get a 6 lug conversion for the NBS 10.5" axles. If you feel like doing a little welding and a disc brake swap, you can snag a 6 lug 9.5" SF for the OBS trucks.
There's two here in FL....and that's the only two listed on this website in the Southeast...
2001 Rear Axle Chevy Suburban 2500 4X2, full-fltng, 3.73 ratio GT4- 17K C32330 Price=$Call LKQ - Crystal River USA-FL(Crystal-River) E-mail 1-800-541-3011 2002 Rear Axle Chevy Suburban 2500 4X2, full-fltng, 4.10 ratio opt GT5-DISC 28K C35185 Price=$Call LKQ - Crystal River USA-FL(Crystal-River) E-mail 1-800-541-3011 |
Sweet! A 6 lug 10.5" would be killer. How much is that conversion kit? |
I have to find it again. Its a very pricey option though......
if you're referring to the late model suburban/tahoe swap, remember that the 3/4 ton suburbans were leaf spring rear and the tahoe/suburban 1500 were coil spring/5 link. considerably easier to just beef the hell out of the 8.6.
Damn,those are expensive I think I can have a 12bolt or 9" Ford custom built for cheaper.The rearend Scream posted on was quoted at $1800,that's to high for a used rearend.
