Best Cam for Radix????????
Old Nov 28, 2004 | 07:36 PM
  #21
O3GMC's Avatar
12 Second Club
Originally Posted by Ryan23silverado
I have an 02+ ls6 cam available if someone wants it. I just took it out for another cam. For boost, the ls6 has a little bit much of overlap.
I dont know much at all about cams, but I thought with the 117 lsa it wouldn't have much overlap - or is it because of "wide split" of the durations?
Old Nov 28, 2004 | 08:24 PM
  #22
Yellowsierra's Avatar
I called allen up and asked him about a cam for my whipplechargered sierra. He said to try to stay under 220dur and a high lift. I went with the lunati 558/558 lift 221/221 dur cam and the grind is Lun55004. I could tell a big diffence in this cam. My 1/4 mile runs went from 13.7 99mph to 13.4 103mph.
2002 GMC sierra 3.73, whipple, lunati cam, and soon to come built 5.7 ls1 with low compression diamond pistions 8.8/1 and 4l80e
Old Nov 28, 2004 | 08:25 PM
  #23
I called allen up and asked him about a cam for my whipplechargered sierra. He said to try to stay under 220dur and a high lift. I went with the lunati 558/558 lift 221/221 dur cam and the grind is Lun55004. I could tell a big diffence in this cam. My 1/4 mile runs went from 13.7 99mph to 13.4 103mph with my 4.8.
Old Nov 28, 2004 | 08:34 PM
  #24
Sweet sounds like you have an awesome setup going on there-Mid 13's in a 4.8 im very impressed with these engines with mods. Good luck on everything and keep us posted.
Old Nov 29, 2004 | 09:01 AM
  #25
marc_w's Avatar
Everything has been pretty well covered so far.
With a blower cam, you generally want to keep the overlap low - the easiest way to do that is keep the LSA numbers higher. Duration and valve timing also play as much of a part in it.
When you have more overlap, you have more of a chance of some of your intake charge getting 'blown' out the exhaust before the exhaust valve closes. Bad for fuel economy, emissions, and power.
Old Nov 29, 2004 | 09:36 AM
  #26
Todd@AZPowerAndSound's Avatar
sold..my buddy is looking for one
Old Nov 29, 2004 | 10:43 AM
  #27
2toneblown's Avatar
The baby blower cam I have that was in my 5.3 w/ Radix was a 214/224,559/567, 114 +2. I liked it. It didnt cam too much but helped alot
Old Nov 29, 2004 | 01:05 PM
  #28
Sport Side's Avatar
Or if you are shooting after the proper ve's for your setup and they require a tight lsa to be used. You can run less duration.
A blower is cramming more air in the chamber more efficiently. So more duration isn't really needed like it might be for a cam-only setup.
Old Nov 29, 2004 | 07:15 PM
  #29
Im probably going to wait on the blower for a while and run the setup i have ordered then play with a cam.
Old Nov 29, 2004 | 07:17 PM
  #30
moregrip's Avatar
what a rush!
ah fooey
