best cam for 4.8
I have a 2003 gmc reg cab bell tech susp. On 20,s
cold air, 410 gears i purchased an ls1 hot cam
for a good deal it has 224., 228,.with 525/525 lift with
ls6 valve springs will this work in my truck
i plan on getting a good stall converter and tune.
The hot cam is made mainly for sound. I've never seen any nice time put down by one. It is hard to tune because of the lobes they are cut on. Honestly you probably will not be satisfied with it. I would pick up a converter first. You will see bigger gains out of a converter and then you can pick up a used tsp220 or tr220 and have a really stout setup. I had a 4.8 with headers, efans, 8.1inj, tci3000 stall, and 3.42 gears that went 8.80's. I've saw 5.3's with the hot cam, stall and gears that only ran 9.0's. The 220/220 551/551 112 would be a really nice cam that will make really nice power through out the rpm's. The 218/218 would be a nice cam.
Even though those lobes are 224/228 the type of lobes they were cut on make a big difference. You would benefit more from a larger lift cam also. You would probably make more power with a lower duration cam with a higher lift..
Castro45
24
Jul 31, 2015 07:13 PM
Suburban2500
Jul 19, 2015 04:50 PM
