Best Budget Full Exhaust?
Old Dec 16, 2022 | 12:49 PM
  #31
blackdak318's Avatar
Originally Posted by RDF1
I can email you my tune if you want. I use EFI Live 99% of the time but i do have HPTooners. Which ever one you were to get, there are plenty of guys on here that would help you out. Ive had my 2500HD for about 3 years now and just yesterday i got to tinkering with how it cranks so RPMs dont flare up to 2000 and then fall to 600. And i mess with shift points and TCC Lockup a little trying to get it just right.
My Tow/Haul locks TCC at 24mph in 2nd and stays locked thru 4th so it doesnt build heat on the back roads towing heavy and pulls a little better.
I may take you up on that!! Thanks, I'll be in touch.
Old Dec 16, 2022 | 02:01 PM
  #32
Fullpower's Avatar
My Tow/Haul locks TCC at 24mph in 2nd and stays locked thru 4th so it doesnt build heat on the back roads towing heavy.
... That is an interesting strategy. I will have to consider ramifications.
I have done near opposite: My tow haul settings all delete TCC lockup, and lockout OverDrive ( upshift to 4th at 255 mph, downshift to 3rd under 237 mph )
Old Dec 16, 2022 | 02:41 PM
  #33
Bgbldodge's Avatar
Why would you not let the converter lock while towing? That's a good way to build a ton of heat not to mention lose the efficiency gained by locking the clutch up. I can see raising OD to not upshift until higher speeds like 60-65mph but locking it out completely?
Old Dec 16, 2022 | 04:05 PM
  #34
smokinlmm's Avatar
I hope he is using it for performance, that's what I did at first. Now I just leave that button off and roll on out. Lol..
Old Dec 17, 2022 | 01:19 AM
  #35
RDF1's Avatar
DuNnO
5 Year Member
Not sure how you use yours but towing 25k# on the back roads I can get my trans Temps up to 250 no problem.
Locking the converter and keeping rpms above 2500 in every gear and trans will barely get Over 150* I have my shift points and lockup set so it never sees less than 2500 rpms and part throttle shifts are between 3500-3700 rpms.
its not set to see 4th gear till 75-80mph.
tjmath
32
Feb 13, 2020 05:54 PM
Badergr1
35
Sep 22, 2017 12:57 PM
FELONIOUS1
36
Jan 19, 2017 07:13 PM
SLOPONY
Aug 7, 2016 07:32 AM
SMOKIN01TA
Jul 17, 2005 12:14 AM
