BBK fly by wire
Originally Posted by TouchOfEvil04
Just get a shaner tb.http://www.s2performance.net/
They don't make a larger mm TB over stock either. I always thought going with a larger mm TB over stock would be the most benificial. Of course as long as you have the mods to support it. How much gain does a ported O.E. TB even give you? Just trying to figure the money to performance ratio on this one.
Jim
Jim
Jim
Originally Posted by Pjstucn
Any one have the BBK fly by wire throttle body? if so is it a good buy?
Originally Posted by FlaBouy
I have the BBK 80MM on my raggety ride. The only problem I had was the blade sticking and causing me tuning issues. It was when I went to drill a hole in the blade to allow more airflow that I found the sticking issue. Had to close the hole back in.......
Did you notice any gains or have dyno results showing a gain from the BBK 80mm unit?
Of course I added it with the cam, heads, rockers, Injectors, and Pacesetter LT's...............
Yeah minor gains.. I went from 407 rwhp to 500 rwhp...
I was about to say! A BBK 80mm TB was almost on order!!!Jim
