Bad Vibration
Old Jan 8, 2004 | 04:08 PM
ChevyTrukRacer99's Avatar
Default Bad Vibration
Ok guys, I needs some help:
I am having a bad vibration under normal acceleration at about 1000-2000 RPM's and also under acceleratin at about 50 MPH. I have changed all the U-Joints and tranny mount. I shimmed the rear end so the pinion angle was up a little and it made it a little better, but that's when the vibe at 50 started. I have 2" drop shackels and when i look at my leaf springs they have a little bit of a negative arch behind the rear end housing. Any help would be geatly appreceiated.
Thanks,
Dereck
Old Jan 8, 2004 | 06:02 PM
one03sierra's Avatar
Formerly one92rs
Lightbulb
you need to check you carrier bearing out. negative arch. mine doesnt have that. is it soft in the rear
Old Jan 8, 2004 | 07:36 PM
What do you mean soft in the rear? I think i may try the carrier bearing but it's like 90 bucks, and i have already spent like 200. But I really want to make it right, I am so frustrated with this, i'll do just about anything to fix it.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
