bad fuel pump, I think.
Old Jul 21, 2006 | 08:36 PM
TURBO8's Avatar
Default bad fuel pump, I think.
Well, I thought I heard a hissing noise by the fuel pressure regulator, but there was no visible leaks. Motor feels strong, when running, but has been starting kind of hard since the ls1 intake install. I put a gauge on the fuel rail to see what my pressure was, and I got 55psi idle, vacume off 65psi. But as soon as you turn the motor off the pressure drops to 0 psi. I am thinking my intank fuel pump may not be holding the pressure. I also have an inline 255 walbro pump. Do you think my intank pump is bad? Or is there a regulator issue? I figure the reg was ok if you pull the vac and preasure goes up.
Old Jul 21, 2006 | 08:38 PM
TURBO8's Avatar
I think I need a fuel preasure gauge in the truck to see what is happening in boost. I wonder if I am loosing preasure in boost?
Old Jul 22, 2006 | 07:28 AM
vanillagorilla's Avatar
Dude, you NEED one in the truck. With the amount boost you're running and the power your making, it's a must.
Old Jul 22, 2006 | 09:18 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Hmmmm. Going to zero would make me think the FPR is on its last legs.
Definately get the fuel pressure gauge in the truck!
Old Jul 22, 2006 | 09:36 AM
TurboGibbs's Avatar
I agree. I prettu sure the pump doesn't hold pressure on the rail. The regulator does as far as I know??? Or at least it is the only other component that could I think.
Old Jul 22, 2006 | 09:51 AM
Don't forget about the filter either. It's cheap and easy to eliminate that variable.
Old Jul 22, 2006 | 11:15 AM
allscrewedup's Avatar
the in tank fuel pump does hold pressure. if not it will cause extended crank hard re starts
Old Jul 22, 2006 | 01:20 PM
TURBO8's Avatar
I have just changed the fuel filter, so should I changed the fuel preasure regulator? by the way thanks for any help you guys can give.
Old Jul 22, 2006 | 02:49 PM
The fuel pressure regulator will not cause the fuel pressure to drop to 0psi. I would not put on a new regulator for this problem. I have been a GM service tech for 24 years if that helps.
Old Jul 22, 2006 | 11:18 PM
TURBO8's Avatar
The pump it is, thanks allscrewedup.
