He just came and put a tune in and made sure it started. Last night it was really bad when I took it out. Like it would almost stay up if I rev'd it up. That just doesn't seem normal to me. Does anyone know if I can just have someone one here like Wheatley or another person that uses HPTuner since I already paid for the license? I really need this done ASAP.
Originally Posted by 4.8T
your base runing idle airflow is set too high. it will cause it to act like cruise control.
(Post 4147569)
your base runing idle airflow is set too high. it will cause it to act like cruise control. or a vacuum leak, did you get the valve cover lines all hooked up?
Originally Posted by MikeGyver
(Post 4147574)
So that means the tuner adjusted it, doesn't it? I ask because mine was so opposite the way it first ran.
pull the valve covers and make sure everything is good and then if it is, call a real tuner like Charlie and have him hook it up!
when mine was driving like shit and backfiring my fuel pump was bad. i also changed my o2's and that helped.
(Post 4147574)
Originally Posted by Jtbrewer19
(Post 4147573)
You're off a tooth, classic symptom
I'm with ^^^^. Missed the cam to crank timing, possible valve to tight, but hard to do with the non adjustable rockers, plug wire or plug failing under load. It could be going lean but running okay before cam swap... so look at the things touched during that.
