autoTrak and 4l80E
Old Aug 21, 2004 | 10:00 PM
James B.'s Avatar
Originally Posted by parish8
does anyone know what front diferential the 1500hd's/2500ld's have and does it have some type of elocker/airlocker available?
I'm fairly sure it is the 9.25"
Eaton makes an E-Locker for it, part number 19622-010, and one for the 9.5" semi float 14-bolt rear as well, part 19684-010. These were developed for the Hummer H2. In the Hummer they will not engage over 7mph or stay engaged over 20mph. I'm not sure if the limitation is in the electronics or some type of centrifugal mechanical internal switch. Almost anything can be bypassed where there's a will...
Old Aug 21, 2004 | 10:55 PM
parish8's Avatar
single digit dreamer
does the hummer have the 2500ld front end parts? a front locker could help me a lot.
i have a junk front diferential from a 2500hd and it would be dificult to get under my truck, the flanges are 2" farthur apart. i would like to know if the 2500ld/1500hd unit is larger than the 1500unit but smaller than the 2500hd unit.
Old Aug 21, 2004 | 11:20 PM
James B.'s Avatar
does the hummer have the 2500ld front end parts? a front locker could help me a lot....
The H2 is based on 2500 suspension and some drivetrain parts (not trans and xfer case), so it's probably the same, with the same dimensions, as what you already have.
Old Aug 22, 2004 | 09:49 AM
moregrip's Avatar
what a rush!
Parish, the 1500HD and 2500HD have the same front diff, the AAM 925.
They do have different frames though, so the 1500HD 925 might be closer.
I'll get some pics up later on today
Old Aug 22, 2004 | 10:02 AM
parish8's Avatar
i know this is asking a lot and may not even be posiable with the case in the truck but if you can get a measurement of the width of the unit that would tell me most of what i need to know. from flange to flange as if the unit was out of the truck.
if it is the right width i am sure i could get it to work. if it is wider then i need to look at the rest of the front suspension and see if i can swap it all over. if it is wider and the front suspension is diferent then it will be hard to get it to work.
Old Aug 22, 2004 | 04:09 PM
moregrip's Avatar
what a rush!
I can tell you straight away that the 8lug, AAM 925 is wider than the 6lug, AAM825.
I will see what I can do on the measurement (hub flange to hub flange), but isn't the suspension mounting points more important?
Old Aug 22, 2004 | 05:06 PM
parish8's Avatar
what is the 6 lug aam825? i thought the 1/2 tons had something tiny like a 7.5".
Old Aug 22, 2004 | 05:23 PM
moregrip's Avatar
what a rush!
http://www.aam.com/technology/tech_p...frontaxle.html
here's the link to the company that makes some of the front axles Chevy uses.
Old Aug 22, 2004 | 05:26 PM
moregrip's Avatar
what a rush!
maybe it's the AAM725 then. I am sure the 1500HD's are the AAM925's, well, at least that's what AAM told me. I thought the 1/2 tons came with the AAM825, but maybe it is the AAM725.
Old Aug 22, 2004 | 05:40 PM
parish8's Avatar
it is kind of hard to tell but do they offer posi units for all of their front ends? that would be sweet.
