AUTOTap'd some stuff...interesting results read on...
Old Jul 28, 2003 | 10:45 PM
Hit Man X's Avatar
Default AUTOTap'd some stuff...interesting results read on...
Well I went to AutoTap the truck tonight it was around 90*F at 9.30PM and got some results...
Looks like that BB mod didn't help me one damn bit, I still run at the high 180's at cruise and low to mid 190s in stop and go driving. Or maybe I have a HUGE air pocket, but I doubt it. Looks like I just suck at free mods. Time to source out a 172* LS1 or a Hypertech 160*. Maybe it has something to do with me using a '99 Model thermo?
More queerness from the stock thermo was that it had 100*C or 212*F stamped on it! Anyone know what this means?
Trans temps stayed around the mid 170's to low 180's, not too hot not too cold.
I have an open K&N FIPK on my truck. My Air Intake Temps were 2-4* over ambient for most of the time. I drove about with the plate under the filter on for a while. This took the AIT's a bit of time to come back down from 110* or so. But they came back to 2-4* over ambient a bit slowly. So next I pull that plate out and cruise again. Same stretch of highway, left truck running while I pulled plate...AIT's drop significantly faster with the plate off.
Shift times: most were around 0.25-0.18 sec range...a quick WOT 1-2 resulted in a 0.08 sec upshift! I think that is pretty damn fast.
My throttle opens to 99.6% already too...
All for now
Old Jul 29, 2003 | 02:01 AM
Flyer's Avatar
Default Re: AUTOTap'd some stuff...interesting results read on...
I have the 160* thermo, but notice my temps up around stock temps around town and when it's under a load. I think it is just at the limits of cooling at that point. I do notice that when it is cooler out it will come on down. It usually seems to be about 88-90 where the break point is for me. I have a bigger raditor to install though, hopefully that should take care of that.
My trans temps stay at about 180-190 (going by the gauge). I would like to see them come down since I have 2k invested in my tranny plus the TC.
That's good about the intake temps (IAT, not AIT , that was kinda throwing me off at first). I wish I could keep mine that low. Maybe I should try one of those kits rather than tthe Volant box. My IAT's stay about 30-35 above if I keep it out of boost, but will raise quickly when the pedal hits the floor.
Old Jul 29, 2003 | 06:41 AM
one03sierra's Avatar
Formerly one92rs
according to the predator my IAT;s start out at around 100 to 110. last night i was driving around and it got down to 82.that is with a upd and ram air mod.
Old Jul 29, 2003 | 08:47 AM
Patrick G's Avatar
LS1 Tech Administrator
IAT= Intake air temperature.
IAC= Idle air controller.
Two completely different things.
Old Jul 29, 2003 | 11:24 AM
BigKID's Avatar
I have a 160* stat and efans my temps stay between 183-186 all the time.
My IATs with the gen2 also stay pretty close to ambient temp but climb on up there when at a stop.
Tranny temps stay pretty close to 150* in the summer with the B&M supercooler.
Old Jul 29, 2003 | 12:49 PM
Hit Man X's Avatar
I have noticed that my coolant temps go to the middle of the stock gauge and stop there for a while, then slowly continues up...think I got an air bubble?
Oh I did have some knock retard around 2-4* cruising around. Is this normal for a stock ride?
Old Jul 29, 2003 | 01:04 PM
ranwalk's Avatar
Sounds like it may be some air in the system
I see some KR at part throttle also.I'm not stock,but I think it's normal.I don't see any KR at WOT.
Old Jul 29, 2003 | 01:10 PM
Flyer's Avatar
I see a little KR (about 2-3* at most) at about 55mph accelerating at about half throttle right. I don't think it is anything major. It goes away wiht octane booster. I'm not to worried about it since it's so low.
Old Jul 29, 2003 | 02:41 PM
BigKID's Avatar
I never see KR at part throttle but get a pretty good bit at WOT.
Old Jul 29, 2003 | 04:57 PM
03rado's Avatar
so this means I should pull my plate off? Also does your filter get dirtied ALOT faster with the plate on? If I take the plate out I was looking at getting one of those prefilter things...good idea or no?
Thanks
