Autotap vs. Ls1 edit
Old Mar 30, 2003 | 11:16 AM
OrangeDice's Avatar
Default Autotap vs. Ls1 edit
Is there a big difference between Autotap and LS1 Edit? Which do you perfer?
Old Mar 30, 2003 | 11:22 AM
JSmith's Avatar
Default Re: Autotap vs. Ls1 edit
Yeah there is a big difference between the two. Autotap lets you see what your truck's engine/drivetrain is doing and LS1edit lets you change parameters. They should be used together. You make your tuning adjustments with LS1edit and then see how well they are working and if there are any problems with Autotap.
I see your from Michigan, do you mind my asking where?
Old Mar 30, 2003 | 03:14 PM
OrangeDice's Avatar
the northern Detroit area
Old Mar 30, 2003 | 03:34 PM
OrangeDice's Avatar
Thanks for the info. By the way that is one sweet ride you got. later
Chavette
Oct 28, 2015 07:33 PM
sprayed99
Sep 21, 2015 04:47 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
brandon_6667
Sep 6, 2015 04:49 PM
