-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Atk lq4 hp93 (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/atk-lq4-hp93-527861/)
GMCtrk Aug 5, 2015 10:45 PM
Factory knock settings, especially on 6.0 motors, are set extremely conservative from factory. I recommend changing to c5 z06 knock sensor settings.
Not to mention, I believe it is nearly impossible to blow up one of these motors naturally aspirated.
madmann26 Aug 30, 2015 03:20 AM
I did this swap last week and used this advice.
JFC this thing pulls like a freight train with my Circle D 3200 and 4.11s.
Nothing but smiles.
madmann26 Sep 13, 2015 07:28 AM
Nothing but smiles.
I'm about to do my first oil change.
So far, zero issues with this engine. I will post the cam they are using in case it helps someone else:
http://www.competitionproducts.com/mobile/Howards-Hydraulic-Roller-Cam-Chev-Gen-III-LS-Series-3-Bolt-216_224-050-551_551-114-LS/productinfo/190235-14/#.VfVqonrD_qA
Even on a 114, it still lopes well. It surprised me.
As far as how it runs. It is definitely every bit of what they claim. I'm not running the timing they suggest but I am running around 28 degrees right now.
I'm still working on trims. Below 4400 is +-1. I just need to do the upper rpm range.
I'm happy so far.
gagliano7 Sep 16, 2015 07:51 AM
Howards, Hydraulic Roller Cam, Chev Gen III LS-Series 3-Bolt, 216/224 @ .050, .551/.551, 114 LS-Competition Products
I'm happy so far.
What timing do they request?
madmann26 Sep 16, 2015 08:22 AM
36 degrees.
That makes me a little nervous tbh.
03sierraslt Sep 16, 2015 09:34 AM
That's too much for pump gas.
madmann26 Sep 16, 2015 09:56 AM
Oh I agree.
gagliano7 Sep 18, 2015 07:42 PM
Originally Posted by madmann26 (Post 5312091)
36 degrees.
That is probably for a carb setup.
slic25hd Jan 11, 2016 10:57 AM
Sorry Gang its been a while since I have been on here but now I have taken the ATK to the next level (78mm turbo,60lb inj, airtoair) My dyno numbers were 405 RWHP at 7LB and 520rwhp at 12lb. Oh boy does she run like a champ now!!! 7.02 MPG haha
madmann26 Jan 11, 2016 11:04 AM
Nice.
Seems kinda low RWHP. I was hoping for close to 400 to the tires myself. I'll be able to tell you for sure next month.
I've got some time scheduled for a Whipple install. :D
I'm shooting for 10-12psi.
