ASP vs Powerbond vs stock pullies compare-o
#50
11.0 Moderator
I didn't say that. Anything that helps even the tiniest bit will in turn drop your ET. Removing weight drops your ET. Removing rotating weight helps exponentially. Imagine taking 100 lbs out of your truck. It will lower your ET a bit. But if those 100 lbs came from a wheel swap it will drop your ET a whole lot more. It's simple physics it all has to do with rotational inertia (momentum).
