ARP Head Studs
Old Nov 26, 2003 | 11:14 PM
IslandTahoe's Avatar
Default ARP Head Studs
Are the torque specs for ARP Head Bolts the same if I am using ARP Head Studs?
What would the torque spec be for the ARP Crank Bolt?
Thanks
Old Nov 26, 2003 | 11:24 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I would call them on their toll-free number and ask the folks in customer/tech support. I've talked to them before and they are good people.
I looked on their web site www.arp-bolts.com under torque specifications and I could only find the torque values for studs. I think that the proper value for bolts will be a little higher (probably about 15%) than for studs to get the same tension on the fastener, but that is purely a guess on my part. Also, they will want you to use their special moly assembly lube.
Old Nov 27, 2003 | 04:17 PM
If I followed JMX's torque guidelines from his "LS1How-To" site for ARP Head Bolts, I got to think the ARP Head Studs requirements would be real similar.
Any thoughts?
03chevytruck
Nov 7, 2016 04:43 PM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
ChevyLee
Jul 10, 2015 10:56 PM
NuckenFuts
Jul 9, 2015 08:45 AM
