ARP head bolt torque specs
Old Oct 6, 2010 | 06:17 PM
SmokinHot98's Avatar
Default ARP head bolt torque specs
OK, the paper says 75ft-lb but that seems excessive for the tiny bolts by the cathedral ports on the heads.
what are the specs for them, factory was 22ft-lbs on the TTY bolts.
Old Oct 6, 2010 | 09:25 PM
Mrgoodwrench3's Avatar
The large bolts are 75 ft lbs. You need to do it in 3 steps. 33/55/75
The paper that comes with the bolts has the specs on it. Factory bolts are stretch bolts and use a different torque procedure. I recommend using ARP Torque Lock lube on the bolts for the best results. The small bolts are 22 ft lbs.
5.3Okasai
Mar 9, 2022 01:07 PM
Denali08
Aug 9, 2015 04:34 PM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
NuckenFuts
Jul 9, 2015 08:45 AM
