Anyone use this SuperCharger?
Old May 17, 2005 | 01:54 AM
  #41
VTODD's Avatar
anybody know if a mail order tuner could tune this? i wonder if procharger type tunes would work with it.
Old May 17, 2005 | 02:22 AM
  #42
redaddiction's Avatar
If you want to run fi I'd suggest getting a real tune.
Old May 17, 2005 | 02:40 AM
  #43
VTODD's Avatar
ur right. good thing iam moving closer to chicago. hopefully speed inc. can hook me up when that day comes.
Old May 17, 2005 | 08:35 AM
  #44
Kevin@W2W's Avatar
LS1TECH Sponsor
Once we have kits available tune ups will be available also.
I saw some questions through out the thread I would like to shed some light on.
Some have noticed the Rotrex units use higher step up numbers than some counter parts. The planetary design of the drive system allows this which is also a reason why the the units are smaller than most have seen. The compressor side of the units are actually turbo castings.
As far as kits we will have complete bolt on kits available for GM trucks, some cars, and even some other car builders. Plus we sell just the supercharger so customers can fab their own kits.
Rotrex suggests using an oil cooler once oil temps reach 177 degrees. Anything below that is not needed and we have yet to see any vehicles in America needing to use one.
I'll see if I can get some pics for you guys. As far as numbers I don't have those yet but will post them as soon as I see them.
Thanks for the intrest guys.
Kevin
Old May 17, 2005 | 09:38 AM
  #45
zippy's Avatar
if you bought one of those i think i could probably fix your tune issue.
Old May 17, 2005 | 11:23 AM
  #46
VTODD's Avatar
i would appreciate that zippy. that wouldnt be a problem for me to drive up there. i checked last night, and from la salle, IL to grand haven, mi is just at 4 hours. map quest always exagerates as well. i could be there in around 3 hours flat.
thanks though
todd
Old May 20, 2005 | 07:31 PM
  #47
BigBlockChev572's Avatar
Any updates yet?
Thanks,
Philip S.
Old May 20, 2005 | 08:05 PM
  #48
tmod's Avatar
http://www.koenigsegg.com/thecars/en...?engineering=2
The Koenigsegg CCR uses two Rotrex superchargers...
It does nearly 240 MPH...if the fastest production car in the world uses them I'm sure they're good enough for our trucks.
Old May 21, 2005 | 12:53 AM
  #49
427's Avatar
427
Kevin will give you a better update later, but here are a couple things we did tonite on our test truck.
The truck is a std cab short box 5.3 automatic. Ran it at the track with 20 inch SS Silverado wheels and tires about 3 weeks ago. Best ET 15.41
Put a rotrex blower with a air to air intercooler in the grille. Max boost is about 8 psi@ 5600rpm. All other parts are still stock. Best ET 13.96
The truck is fun to drive and the blower is very quite even at full throttle.
Kurt
Old May 21, 2005 | 01:11 AM
  #50
moregrip's Avatar
what a rush!
Kurt
very nice.
