Anyone running a FAST intake on a DBW application???
Old Oct 20, 2009 | 10:19 PM
scotthughes's Avatar
Banned Scammer
i really really want the 102mm. when dose it come out for trucks? i was about to by the 96mm from vengence racing. which is the 92mm from fast but ported
Old Oct 21, 2009 | 08:27 AM
I really don't know how this applies to my question?
Old Oct 21, 2009 | 08:29 AM
I really wish FAST was able to make a DBW 92mm TB. Everything will be going to DBW eventually.
Old Oct 21, 2009 | 03:15 PM
Banned Scammer
Originally Posted by SweetS10V8
EXACTLY!!!! I wish everyone understood this!!!!
Boost is a measure of restriction, not airflow!!
Get rid of a restriction, aka crappy intake, and you pick up airflow. Airflow is how you gain power. This means with a less restrictive intake you get more power with LESS boost!!! Which is easier on parts!
Then if you want you can turn the boost back up, and gain even more power!
I have a FAST LSXR on a DBW application.
The truck version LSXRT is going to be out soon too
it applys more to his post actually then to your question. sorry.
Old Oct 21, 2009 | 09:56 PM
SweetS10V8's Avatar
Originally Posted by Silvy6.0
So what I'm getting is FAST for N/A and LS6 for boost.
I dont think thats correct at all, airflow is airflow no matter if your forced induction or N/A.
The saying "no replacement for displacement" is becuase more displacement moves more air which equals more power.
Ive also heard the saying "no replacement for displacement, or boost" which boost artificially adds more air which equals more power just like displacement does.
You want more airflow to make more power!!
Old Feb 20, 2010 | 04:45 PM
DrX's Avatar
DrX
You can put a NW 102mm DBW TB on these.
Attached Thumbnails Anyone running a FAST intake on a DBW application???-102mm-tb-ifast-lsxr.jpg   Anyone running a FAST intake on a DBW application???-fast-lsxrt.jpg
Old Feb 21, 2010 | 04:23 PM
4.6 eatin gm's's Avatar
so when is the truck 102 intake projected to come out? and cany anyone post a link to there website?
Old Feb 21, 2010 | 05:04 PM
DrX's Avatar
DrX
www.fuelairspark dot com
Old Feb 21, 2010 | 05:54 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by CI DENALI
If you're going the forced induction route, I would go with either the carb style Victor Jr with an elbow or the new Edelbrock Pro-Flo XT. Either one that can fit a 4-bolt 87-90mm throttle body can work with a DBW Throttle body, but you will have to change fuel rails etc. to fit, so it could get expense. The FAST (and factory) manifolds are designed for maximum cylinder fillings over a range of rpms/throttle positions on a naturally aspirated motor, so they make the runners longer to boost velocity, whereas forced induction takes care of that with boost.
However, on a N/A motor, the carb style/elbow or Pro-Flo XT manifolds, will give up a ton of midrange torque and HP to the factory or FAST, so if it's N/A, the FAST is the way to go.
Of course, if you're going to a Radix TVS (or other roots style) setup, they conveniently take care of the manifold at the same time.
That's my 2 cents anyhow...
I disagree. Both the Vic Jr and the Pro-Flo are going to be pretty equal in a boosted application (and no doubt they will be better for boost than NA), but the FAST will out perform both of them.
Old Mar 7, 2010 | 12:01 AM
do u need to run special fuel rails to run this intake? if so which ones?
