Anybody else's Throttle body blade sticking in the cold weather?
14 Second Truck Club
It's my fault because I did the tb coolant by-pass mod. It just sucks going 35 and being stuck at 3000+rpms. It's kinda like its in 1st gear sometimes.
i know mine starts to stick every 3 months or so because of carbon build up. try some TB or carb cleaner, a toothbrush, and a rag to clean all that black build up out of the TB. if that doesn't work, maybe it is the TB bypass mod.
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by chris99gmc
well i haven't done the bypass mod and Mine sticks. It started to stick last winter, and then I cleaned the flap. Now it's starting to stick a little bit again.
I hear XLR8NSS has some...but he won't share.
Originally Posted by Chingon
It dipped down into the 40's last night and mine didn't stick shut
I did the TB bypass mod too.
I did the TB bypass mod too.it is 0deg and droping here right now.
Remove the TB and "hone" out the inside walls of the TB and lightly shave around the edge or the "valve" itself. Kind of like Honing and Polishing a head or cylinder.
I have 2 new still in shrink wrap Throttle Bodies that will fit your truck, I'd sell you if you want to do the modify-repair on either the new or old one. That way you always have a spare bolt-on replacement. I'd take $50 for it. They sell for around $300 new at a GM Dealer.
Later.
