any1 have a built 4.3L?
Old May 25, 2006 | 10:19 PM
Default any1 have a built 4.3L?
anyone have a built 4.3L i plan on building one in the near future for a 175shot of nitrous plus getting a built 4l60e
Old May 25, 2006 | 11:00 PM
Question
Any particular reason why?? Why not build up a V-8?? Are gas prices hurting you that bad? Just curious. I know the 4.3L weighs a little less than the V8's, but not all that much. For the power advantage, the V-8's have a better advantage. Will be cheaper to mod a 4.8, 5.3, or 6.0L engine to get the power you will not get out of the V6. Not knocking your idea, but it just doesn't seem logical. Not for a truck at least.
Jim
Old May 25, 2006 | 11:11 PM
hrodgmc's Avatar
Ask some of the syclone guys. They get really expensive when you push them.
Old May 25, 2006 | 11:30 PM
Full_Pull6.0HD's Avatar
A friend of mine has a sonoma he started modding the 4.3 in before he bought his LT1. I remember him saying parts for it such as cams and heads were actually more than V8 componets. I'm assuming this is because of the niche market the sixers fall into.
Old May 26, 2006 | 11:07 AM
three83's Avatar
HotRod Mag. did a build up on a 4.3L a while back, the article was on there website. Might want to search their website for it.
Old May 26, 2006 | 10:05 PM
Jims-ZR2's Avatar
I've got alot of mods done to my 4.3. People tell me I should put a V8 in my ZR2. But alot of guys do that, it's not even impressive to see a 8 in a S10. I have the same reason as hot rod magazine had, it's neat, not many people build V6's. And actually my 4.3 will out run my friends 99 5.3 in his 4wd Sierra. He has intake, exhaust and headers. I have every bolt on, 4.10 gears and 1.6 full roller rocker arms. Along with my truck being a ZR2 which weighs 4000 lbs, 500 more than a reg 4x4 S10.
If you want performance check out www.machperformance.com They reproduce the Turbochargers that scylones and typhoons used. Along with making a intercooler supercharger for the 4.3. They have 1/4 times listed and most of the S10's are in the 13's, if not 12's....thats just with the forced induction. Add gears, cam etc and your perfomance will obviously increase more. As far as heads and intake, we're basically SOL.
Old May 26, 2006 | 11:04 PM
hrodgmc's Avatar
Brodix makes little brodies for 4.3's, but get ready to wait for them. (usually about 6 months) Vortecs, when worked and not shrouded, will be adequate for most applications.
nabozny21
Oct 17, 2015 07:47 PM
turbo6c3
Oct 5, 2015 06:11 PM
Mark_k
Oct 1, 2015 11:17 PM
jtphelps289
Sep 30, 2015 09:26 PM
DrX
Sep 29, 2015 04:31 AM
