Any TT kits fot trucks?
Old Jan 13, 2005 | 12:50 AM
BLASTER's Avatar
Default Any TT kits fot trucks?
Any twin kits available? I like the STS kit but I just got my duals redone two months ago and really am not all together comfortable with a rear filter. I think there should be enough room in the engine bay for twins. Otherwise I think I might just go with a Radix kit.
Old Jan 13, 2005 | 01:20 AM
F8L Z71's Avatar
What's your HP goal? IMO only reason to go twins would be for 600+rwhp and a ton of cash to burn. Otherwise a simgle front mount would suffice. Livernoise is the only production kit I can think of but I think it is only sold to locals who can have it installed by them unless I am thinking of another kit. PTK has talked of coming out with a truck kit also but I bet it is going to be awhile since the LS1 kit isn't even out yet.
Just remember that the Radix is good and all but if you want over 500rwhp without building a high HP motor to start with then you may be looking in the wrong direction.
*runs and hides from Moregrip*
Old Jan 13, 2005 | 07:55 AM
www.bankspower.com
Old Jan 13, 2005 | 08:55 AM
Green Thunder's Avatar
Twins.... But these wouldnt solve your new dual exhaust situation..
Old Jan 13, 2005 | 10:52 AM
Landyachtz's Avatar
why go twin? From what I've heard with the LS1 based engines, its much more efficient to run one big turbo, rather than a twin setup.
Old Jan 13, 2005 | 12:03 PM
BurnOut's Avatar
F8L- I think that PTK's LS1 kit is available now. As for other turbo kits, what ever happened to the CMotorsports kit that Parish is running?? Last I heard, the guy at CMotorsports that was working on the kit left the company, but they were trying to find someone else to get back on the project.
Old Jan 13, 2005 | 12:09 PM
Less lag... and less money in your check book!
Old Jan 13, 2005 | 12:31 PM
http://www.lingenfelter.com/performance427suvturbo.asp
BAM!
Old Jan 13, 2005 | 12:35 PM
Whistlin00's Avatar
14 Second Truck Club
that lingenfelter turbo setup would be badass.
Old Jan 13, 2005 | 12:37 PM
Landyachtz's Avatar
that would be insane to see a suburban with 700 hp and 740 ft/lbs
