any one ever use this cam?
Old Jan 16, 2005 | 12:52 AM
Default any one ever use this cam?
SDPC Part Number: 12480033
Manufacturer: GM Performance Parts
Advertised Duration Int. : 279°
Advertised Duration Exh. : 287°
Duration @ 0.050" (I/E) : 219°/228°
Lift (I/E) : 0.525"/0.525"
Lobe Separation : 112°
RPM Range : 2200 - 6500
Cam Type : Hydraulic Roller
Getting realy to buy one just looking around and found this one. Just wondering what kinda performance gains I could expect out of it. Is it worth buying? I figure it would be a pretty good cam being its made by GM. Dont realy know any thing when it comes to things like this so I thought I would find out from you guys.
Old Jan 16, 2005 | 01:06 AM
BigTex's Avatar
Thats the LS1 Hotcam isn't it? Lots of LS1 cars used to run it, but found they could make more power and have better idle with other aftermarket cams. I'm sure someone has one in a truck, but I haven't seen anyone on this site.
Old Jan 16, 2005 | 01:10 AM
storm5.3's Avatar
13 Second Truck Club
Deckhand has that one in his 4.8 I think. Ya might want to PM him about it...Zed
Old Jan 16, 2005 | 02:43 AM
sfj
havent used it but what other mods do you have that is kind of a big cam if you dont have a converter and it will be real laggy until the power band hits and then so you would also definately need a tune but as far as the cam itself it looks good i would try it if i didnt get such a good deal on mine but also with the 112 that will prolly lope like a beast as well so may not be for the daily driver if that is what you are looking for
Old Jan 16, 2005 | 10:16 AM
well for right now I just have mostly just the average bolt stuff, and a little N20. I would like something that pulls in that RPM range. Yea its my daily driver and I wont something that pulls like a mule on bottom end and mid range. Also I will prbabllt be shifting out at about 5500-5600 so I dont realy think that I need something that dont start working untill 3500 or so(ex.). I plan on getting a Nelson tune and about a 2000-2500 stall some time or another. Also is getting the heads ported and polished worth the $?
Old Jan 16, 2005 | 01:28 PM
vanillagorilla's Avatar
This cam has a really good split for nitrous. I don't know if you have a 4.8, but if you do, it will be pretty rowdy. As far as shifting, this cam pulls strongly to at least 6400, which is where mine shifts. I would choose a smaller cam if you want to keep you rpms down. Also you'll want at least a 3000stall with this cam too, depending on what gears you have. Nelson does have experience tuning this cam, he's tuned mine and Deckhand's. I like it, and you can't beat the price. There are better cams out there, but you can't beat the bang for the buck, especially if you're spraying.
Old Jan 16, 2005 | 10:20 PM
well what would you guys recomend for me, Like I say I dont really know anything about this kinda stuff. I would like a good cam that pulls like a mule from about 2000 to about 6000, work really well with N20 and has a lope to it. (not beating the ground just sound pretty mean and noticeable.) I would realy like to run about a 2000 stall (I think) Also I have 3.73s in the rear and 5.3 under the hood.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
