any help welcome
Old Jul 10, 2003 | 03:38 PM
lm7's Avatar
lm7
Default any help welcome
i got my cable today...needless to say im a little lost..i was wondering if anyone can give a me a little help with my tune...i have RC 42lb injectors, ATi procharger stock boost, ASM long tubes, and a flow master. im running pig rich the damn thing wont idle, imgoign to buy some new plugs right now so i can replace these because theyre covered in fuel...i need to lean just a bit so i can drive it and log some stuff any help would be very apreciated thanks
Old Jul 10, 2003 | 06:47 PM
GMC SKI's Avatar
Default Re: any help welcome
Did Sam send you his Ls1 edit file
First things first download your stock programme
save it into a ls1edit folder
Next gets Sam's edit file that i helped him with and flash the comoputer
When was the last time the truck was started ?
is there still Fuel on the plugs you have ?
you Can use the Clear flood meathod to start it mash the pedal to the floor and start Cranking away to burn up the gas you have in there
so that for a bit then try to start her up
After she starts you might have to help her idle to let the computer learn the new changes
let it idle for a 30 mins
How old is the gas in your tank?
Don't beat on it if you have old gas in it and get the best gas you can find 94 octane if they have it
After you get all that done post up how and tell us how things are going
Atap it to see how the l-trims are looking at idle
Good luck
Jim
