any diffrences between 5.3 heads and 6.0 heads???
yes sir the lq4-lq9 head assembly is (similar) to a Z06 head in the flow characteristics. not exactly the same. they flow much better and have a bigger chamber if i rememeber correctly.
5.3 truck heads are 1.98ish intake valve, 1.55 exhaust, 62cc chamber head.
5.7 2.0 intake valve, 1.55 exhaust. 67cc chamber.
6.0 same valves as 5.7heads, 72cc chambers.
6.0 heads are same design as ls6 heads.
LS6 heads are 64cc chambers.
5.3 and 5.7 heads are basicly the same in port shapes.
Aprox. #s anyway
Aprox. #s anyway
Originally Posted by CAMMIN03'
what about 6 lt heads and a whopping shot of Nitrous
You don't go low compression with nitrous. If anything you want higher compression. The opposite of boost.
Boost is good for those heads, nitrous isn't, unless you shave the pis out of them, but at that point you'll loose some other important factors and they will loose efeciency or effectiveness.
