another mpg question
Old Feb 23, 2011 | 12:49 AM
5.3waggy's Avatar
Default another mpg question
so the wife drives a 2000 tahoe z71 with a 5.7. it has k&n intake, 3" flowmaster cat back. we have owned it about 4 months now. first checked mpg, was getting 10.4 city all stock. now with mods getting 9.3 mpg. this is with my wife driving. I would think it would be better than that. we really love every thing about it but the mileage. I know its no econo box, but my 97 5.7 2wd silverado gets 16-17mpg in town and thats with me driving ;-) any ideas? it also only has about 3k on complete tune up. I also wouldn't be apposed to ditching all the 4wd parts to save gas if it would be enough of a difference. 2wd's are hard to come by around here. Thanks
Old Feb 23, 2011 | 07:14 AM
01Blackerado's Avatar
Is this a 5.7 Swap? If not then it should be 5.3 ... other than that the only other thing I can suggest is tuning. You threw on a bunch of mods, without a tune you PCM has no idea WTF is going on. All it knows is youre getting way more air and fuel than its prgrammed for.
Old Feb 23, 2011 | 07:31 AM
Chavette's Avatar
Any extra weight you can shed always helps. Tires with low rolling resistance and properly inflated help. A general tune up, timing, and compression check (since it is a 2000) would be a good start. If mechanically sound, you would also probably benefit from having a tune done on it (pcm) as there are a number of things to optimize to add both power and efficiency. There are a number of mail order or local tuner solutions (including sponsors on right) some offering lifetime updates. cheers
Old Feb 23, 2011 | 11:52 AM
Chavette's Avatar
Fyi...there was an early 2000 version of the Tahoe that had a 5.7 as I recall before they went to the new engine line up choices mid year, so it could be the original engine.
Old Feb 23, 2011 | 07:20 PM
5.3waggy's Avatar
it is original engine. its a tahoe z71 classic, old body style. so I guess pcm is off to get a tune. recommendations?
Old Feb 23, 2011 | 07:25 PM
offroadrider12's Avatar
justin at blackbear performance
edit:
you may also want to look into the 0411 pcm swap. It is more tuneable, allows a higher rev limit, and has a few other benefits.
Oh that does change things a bit... I thought they quit that setup in 99. In that case you may need to find someone with the old LS1 edit. You might have a good chance at a tune then. Im not sure if HPT or EFi offer tunning for that PCM honestly.
Old Feb 23, 2011 | 07:47 PM
AJII's Avatar
Sounds like it just needs a tune up.
Old Feb 23, 2011 | 08:07 PM
He said hes only got 3K miles on this tune up
Old Feb 23, 2011 | 08:10 PM
AJII's Avatar
Dammit. I read that paragraph 3x and still missed that part.
