another e-fan ????
Old Feb 21, 2006 | 12:57 PM
ap2002's Avatar
Default another e-fan ????
Im looking around for some efans, and found some that are off a V6 camaro... they are dual fans,, are these the same off a LS1????
thanks....
Old Feb 21, 2006 | 01:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
yup..
Old Feb 21, 2006 | 09:58 PM
ap2002's Avatar
yup..
you better be right Cody if not
Old Feb 21, 2006 | 10:11 PM
Colby 04's Avatar
you sure? I thought they were different for the LS1's....
Old Feb 21, 2006 | 10:15 PM
Colby 04's Avatar
...Just checked an online parts catalog, the motor itself IS the same for the LS1 and the 3.8 V6. Not sure about the shroud and fan size though....
Old Feb 21, 2006 | 10:16 PM
ap2002's Avatar
talks Colby,,
waiting to see if someone else chimes in..
Old Feb 21, 2006 | 10:20 PM
They both have the same Radiator width. Fans should be the same.
Old Feb 21, 2006 | 10:22 PM
TXsilverado's Avatar
what year camaro did they come from? if they arent from the "ls1 era" they might not work...
Old Feb 21, 2006 | 10:24 PM
FILE's Avatar
The 93-97 fbody fans had different fans between the V8's and the V6's. The 98 and up had the same fans regardless if it had the LS1 or the V6 engine.
Old Feb 21, 2006 | 10:29 PM
ap2002's Avatar
thanks, that clears up alot!!!
